I m trying to export a map with a graphic layer but the graphic layer is not being shown in the PDF exported.
How can I show this graphic layer in the PDF result of the PrintTask?
Thanks
Can you post your code?
This is the click event on the Print button. Notice the visibility setting of the layers. There is also another graphic layer (which I would like to show) that is included within the map but is not shown.
$("#btnPrint").click(function () {
require(["dojo/dom", "esri/dijit/Print", "esri/tasks/PrintTemplate"
], function (dom, Print, PrintTemplate) {
showLoading();
RAGMapServer.setVisibility(true);
pointLayer.setVisibility(false);
polygonLayer.setVisibility(false);
polylineLayer.setVisibility(false);
var printMap = new esri.tasks.PrintTask("http://aphrodite/arcgis/rest/services/Layout/WSC_PRINT_TECH/GPServer/Export%20Web%20Map");
var params = new esri.tasks.PrintParameters();
var template = new esri.tasks.PrintTemplate();
template.exportOptions = { dpi: 96 };
template.format = "PDF";
template.layout = "WSC-Print1";
template.preserveScale = true;
template.showAttribution = false;
template.layoutOptions = {
legendLayers: [],
scalebarUnit: "Feet",
titleText: "PIN",
params.map = map;
params.template = template;
printMap.execute(params, printResult);
function printResult(result) {
if (result != null && result !== undefined) {
RAGMapServer.setVisibility(false);
pointLayer.setVisibility(true);
polygonLayer.setVisibility(true);
polylineLayer.setVisibility(true);
$("#btnPrint").empty().append('<i class="fa fa-print"></i><span style="padding-left:7px;">Print Map</span>');
window.open(result.url, "_blank");
hideLoading();
We've had this issue before as well. Not sure if fixed yet (or if even considered a bug), but the only graphics layer that will print is the map's default graphics layer. Any new graphics layer(s) you create will not print. You will need to copy the features to the default layer, or just use the default. You can change the order of graphics once in the default or add polys, then lines, then points to default to make sure they show on top.
Again, hoping this is fixed as I haven't checked lately, but worth trying the default to make sure.
Hi Bryan,
thanks for the tip, just tried this by adding a small for loop to include additional graphics in the map's default graphic layer:
for (var i = 0; i < graphicsLayer.graphics.length; i++)
map.graphics.add(graphicsLayer.graphics);
Still the graphic did not show up.
Just resolved this issue, my graphic had a very low opacity and did not see it before I removed all other layers from the map lol
Hi Brian Cachia , did your graphic layer work or did you need to copy to the default layer? Just wondering since haven't tried in a while.
