def updateParameters(): if self.params[0].value: # get dict of county names and codes counties = {} rows = arcpy.SearchCursor(self.params[0].value,"","","CNAME;CCODE") for row in rows: nm = row.getValue("CNAME") cd = row.getValue("CCODE") counties[nm] = cd del row, rows # set up picklist (filter) of county names cnames = counties.keys() self.param[2].filter.list = sorted(cnames) # set up picklist of place names for this county if self.params[1].value and self.params[2].value: county_code = counties[self.params[2].value] where = "CCODE = {0}".format(county_code) rows = arcpy.SearchCursor(self.params[1].value,"",where,"PNAME;CCODE") pnames = [] for row in rows: pnames.append(row.getValue("PNAME")) del row, rows pnames = sorted(set(pnames)) # uniqueize and sort self.params[3].filter.list = pnames
Could you clarify where and how [validation] code gets applied?
#Import modules import os import sys import arcpy #Set Map Document mxd = arcpy.mapping.MapDocument("Current") #Set Overwrite Option arcpy.env.overwriteOutput = True #Sets parameters (attributes) County = sys.argv[1] Place = sys.argv[2] CountyName = sys.argv[3] PlaceName = sys.argv[4] Office = sys.argv[5] Forester = sys.srgv[6] Activity = sys.argv[7] Persons = sys.argv[8] Underserverd = sys.argv[9] NameLast = sys.argv[10] NameFirst = sys.argv[11] #Create a new row and fill in fields rows = arcpy.InsertCursor("CommunityLevelActivity") row = rows.newRow() row.TFSOffice = Office row.TFSForester = Forester row.Activity = Activity row.RecipientLast = NameLast row.RecipientFirst = NameFirst row.Persons = Persons row.Underserved = Underserved row.Place = PlaceName rows.insertRow(row) del row del rows #Calculate Date Field expression = datetime.datetime.now() arcpy.CalculateField_management("CommunityLevelActivity", "DateComplete", expression, "PYTHON_9.3") # Refresh map to show all changes arcpy.RefreshActiveView() mxd.save() # Refresh map to show all changes arcpy.RefreshActiveView() mxd.save() del mxd,
I am not sure how to include Curt's code into the Tool Validator.
