how do you figure the screen resolution?
private static IDisplay myDisplay; private static Image myMapImage; Graphics g = Graphics.FromImage(myMapImage); g.Clear(Color.Transparent); myDisplay.StartDrawing(g.GetHdc().ToInt32(), 0); for (int i = Map.LayerCount - 1; i >= 0; i--) { ILayer layer = MapControl.get_Layer(i); layer.Draw(esriDrawPhase.esriDPGeography, myDisplay, null); } myDisplay.FinishDrawing(); g.ReleaseHdc();
Hi, basically one way is to draw layer by layer in an image object, then export it private static IDisplay myDisplay; private static Image myMapImage; Graphics g = Graphics.FromImage(myMapImage); g.Clear(Color.Transparent); myDisplay.StartDrawing(g.GetHdc().ToInt32(), 0); for (int i = Map.LayerCount - 1; i >= 0; i--) { ILayer layer = MapControl.get_Layer(i); layer.Draw(esriDrawPhase.esriDPGeography, myDisplay, null); } myDisplay.FinishDrawing(); g.ReleaseHdc(); I hope this is helpful for you
Thank you. But there is an error: Use of unassigned local variable 'myMapImage'Kind regards,Tai
you are rigth, that's my mistake, you have to initialize the variable....
System.Int32 screenResolution = 30; System.Int32 outputResolution = 200; pExport.Resolution = outputResolution; ESRI.ArcGIS.Display.tagRECT exportRECT; exportRECT.left = 0; exportRECT.top = 0; exportRECT.right = activeView.ExportFrame.right * (outputResolution / screenResolution); exportRECT.bottom = activeView.ExportFrame.bottom * (outputResolution / screenResolution);
Hi Xtian79, I found out another way, please see the link: http://forums.arcgis.com/threads/69207-How-to-store-elements-of-IMap%28IGraphicsContainer%29-as-BinaryData-format-in-SQL?p=245080&viewfull=1#post245080Kind regards,
Hi!!!, in the solution that you propose how do you figure the value of the screen resolution?, or is it just a random value? i trying to export an image to the printer, that information would be useful
