featureclass = r"c:\my.gdb\myfc" field = "idfield" id = 1 with arcpy.da.UpdateCursor(featureclass, field) as cur: for row in cur: cur.updateRow(["FIT-{0}".format(id)]) id += 1
rec=0 def autoIncrement(): global rec pStart = 2555 #adjust start value, if req'd pInterval = 1 #adjust interval value, if req'd if (rec == 0): rec = pStart else: rec = rec + pInterval return "FIT-{0}".format(rec)
def addone(fld): if not fld is None: temp = fld.split('/') num = int(temp[1]) + 1 # this will delete leading zeros newnum = str(num).zfill(2) # change 2 to to however many zeros you want to pad the value by return "{0}/{1}".format(temp[0], newnum)
