What was the verdict on this one? I am having the same issue...
I uploaded a CSV file of numeric columns, joined them to my polygons, they show in the attribute table and under >symboloby>categories but NOT under >quantities....
Also, the title of the joined columns doesn't show what it was in excel...instead of my text is says 'field2 field3 field4'.
There was never any additional follow-up from them, so no idea if it ever got resolved. I again extend my offer to look at a copy of the csv.
Also I recommend converting the csv to a geodatabase table, it usually helps clear up a few things prior to the join.
I guess I can just reply to this email instead of messaging...
Best,
Edwin Terrell
I am in the same situation right now. How did you fix the issue on your end ?
Hmmm, it's been awhile (4 years)...I believe I sent it to Ian and he was able to make it work. If I remember correctly he may have simply copied and pasted it into another file. Sorry that's probably not much help, it was a long time ago.
hi. how can i change type of the fields?
I am also having this problem. I have joined a CSV file to my shapefile. It has a large number of columns all of which I can see in the attribute table. Use of the quantities category in Symbology works fine for the majority of columns. But, it is not accessible for columns with the word crafts in the field name. I have tried making the csv file numeric with no effect. Can anyone help?
