this.raiseSelectedGraphicsChange(newGraphic, true); this.raiseSelectedGraphicsChange(oldGraphic, false);
private void raiseSelectedGraphicsChange(Graphic g, bool isSelected) { if (isSelected) { this.selectedGraphics.Add(g); } else { this.selectedGraphics.Remove(g); } base.OnPropertyChanged("SelectedGraphics"); base.OnPropertyChanged("SelectionCount"); }
You are right that when a selection on Graphics is made, "SelectionCount" and "SelectedGraphics" PropertyChanged are both raised. Can you share your code for selecting and unselecting graphic? If you wish to maintain just a single selection at one time, I suspect that you deselect the previous graphic before you select the next graphic. Is that right?
