Into what type of geodatabase are you importing? How is the taget coordinate reference defined?It looks like you tried to set a scale factor appropriate to meters when the units are degrees (fourfewer digits than necessary).- V
Please post the contents of the "Domain, Resolution, and Tolerance" tab from the Propertieson the source and destination layers.- V
