import arcpy from arcpy import env #Setting the env workspace to be an SDE geodatabase # env.workspace = r'C:\sde_at_DB101.sde' #Getting the existing polygon feature class as input parameter # GetExistingPolyFC = arcpy.GetParameterAsText(0) GetPolyFC = GetExistingPolyFC # Truncate a feature class if it exists # if arcpy.Exists(GetPolyFC): arcpy.AddMessage("Polygon feature class exists, start working...") arcpy.TruncateTable_management(r'C:\sde_at_DB_101.sde\%s' %GetPolyFC) arcpy.AddMessage("Truncating table is complete") else: arcpy.AddMessage("Polygon feature class does not exist")
