I created a program in ArcO that has a dialog box that users answer questions in to get an mxd to draw. I missed a step in the program. I have it written where if they choose Annual stations it will draw an mxd from the current year folder. I forgot to program in differeent years. For Example: If they choose Annual and 2010 then it needs to draw the mxd from the 2010 folder. I'm not to sure how to fix my loop. Should it be: If cboStations.Text = "Annual" thenIf cboYear.Text = "2010" ThenSelect Case cboDistrict.Text Case "Abilene" pApp.OpenDocument ("K: .........Code is below:Private Sub cmdMap_Click() Dim UserValue As String Dim Value As String Dim Year As String Dim pDoc As IDocument Dim pApp As IApplication Set pDoc = New MxDocument Set pApp = pDoc.Parent If cboStations.Text = "Annual" Then Select Case cboDistrict.Text Case "Abilene" pApp.OpenDocument ("K:\TASS\4_MAPPING_DATA_SUPPORT\Traffic_Mapping\District_Maps\2012\Abilene\Abilene_Base_Map.mxd") Case "Amarillo" pApp.OpenDocument ("K:\TASS\4_MAPPING_DATA_SUPPORT\Traffic_Mapping\District_Maps\2012\Amarillo\Amarillo_Base_Map.mxd") Case "Atlanta"
