The widget is when we select a feature, the surrounding parcels which intersects with feature, will get a buffer o including the selected feature with specified distance, Any help on this??
You may want to consider to move (see Moving Content) this thread to the Web AppBuilder Custom Widgets place. This is a place which is even more active than Web AppBuilder for ArcGIS with a lot of people working on custom widgets. You may also want to share what you have until now.
The Near Me Widget which is provided with Web AppBuilder has a lot of Buffer functionality and configuration parameters to help custom it to your needs. It could be helpful to reference in your custom widget.
-Lindsay
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
