<UserControl x:Class="Retrospective.MainPage" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:esri="clr-namespace:ESRI.ArcGIS.Client;assembly=ESRI.ArcGIS.Client" xmlns:Toolkit="clr-namespace:ESRI.ArcGIS.Client.Toolkit;assembly=ESRI.ArcGIS.Client.Toolkit" mc:Ignorable="d" d:DesignHeight="300" d:DesignWidth="400"> <Grid x:Name="LayoutRoot" Background="White"> <esri:Map x:Name="MyMap" TimeExtent="{Binding ElementName=MyTimeSlider, Path=Value}"> <esri:ArcGISTiledMapServiceLayer Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer" /> <esri:FeatureLayer ID="vbLayer" Url="http://vmxp/ArcGIS/rest/services/vbgis/MapServer/0" UpdateCompleted="FeatureLayer_UpdateCompleted"/> </esri:Map> <Grid HorizontalAlignment="Center" VerticalAlignment="Bottom" Margin="50,10,50,10" > <Rectangle Fill="#77919191" Stroke="Gray" RadiusX="10" RadiusY="10" Margin="0,0,0,5" > <Rectangle.Effect> <DropShadowEffect/> </Rectangle.Effect> </Rectangle> <Border Background="#FFFFFFFF" BorderBrush="DarkGray" CornerRadius="5" Margin="10,10,10,15" HorizontalAlignment="Center" VerticalAlignment="Top" > <StackPanel Margin="5"> <TextBlock Text="VBs" FontSize="16" HorizontalAlignment="Center"/> <Grid> <TextBlock Text="{Binding ElementName=MyMap, Path=Layers[vbLayer].TimeExtent.Start, Mode=OneWay}" HorizontalAlignment="Left" /> <TextBlock Text="{Binding ElementName=MyMap, Path=Layers[vbLayer].TimeExtent.End, Mode=OneWay}" HorizontalAlignment="Right" /> </Grid> <Toolkit:TimeSlider x:Name="MyTimeSlider" Loop="True" PlaySpeed="0:0:0.15" TimeMode="TimeExtent" MinimumValue="{Binding ElementName=MyMap, Path=Layers[vbLayer].TimeExtent.Start, Mode=OneWay}" MaximumValue="{Binding ElementName=MyMap, Path=Layers[vbLayer].TimeExtent.End, Mode=OneWay}" Value="2000/08/04 01:00:00 UTC,2000/08/07 01:00:00 UTC" Height="20" /> </StackPanel> </Border> </Grid> </Grid> </UserControl>
namespace Retrospective { public partial class MainPage : UserControl { public MainPage() { InitializeComponent(); MouseRightButtonDown += new MouseButtonEventHandler(MainPage_MouseRightButtonDown); } void MainPage_MouseRightButtonDown(object sender, MouseButtonEventArgs e) { // (MyMap.Layers["vbLayer"] as FeatureLayer).Update(); // (MyMap.Layers["vbLayer"] as FeatureLayer).Refresh(); FeatureLayer featureLayer = (MyMap.Layers["vbLayer"] as FeatureLayer); } private void FeatureLayer_UpdateCompleted(object sender, EventArgs e) { TimeExtent extent = new TimeExtent(MyTimeSlider.MinimumValue, MyTimeSlider.MaximumValue); MyTimeSlider.Intervals = TimeSlider.CreateTimeStopsByTimeInterval(extent, new TimeSpan(0, 0, 10, 0, 0)); MyTimeSlider.Value = new TimeExtent(MyTimeSlider.MinimumValue, MyTimeSlider.MinimumValue.AddMinutes(20)); } } }
<esri:Map x:Name="MyMap" WrapAround="True"> <esri:Map.Extent> <esri:Envelope XMin="-15000000" YMin="2000000" XMax="-7000000" YMax="8000000"> <esri:Envelope.SpatialReference> <esri:SpatialReference WKID="102100"/> </esri:Envelope.SpatialReference> </esri:Envelope> </esri:Map.Extent> ......
