How do I update a Raster Field using a cursor? I'm attempting to write a script that uses a cursor to update this field with rasters from a directory. It's a stand-alone script using arcpy for ArcGIS Pro 2.3.1.
arcpy.da.InsertCursor, arcpy.da.SearchCursor and arcpy.da.UpdateCursor state that as a field_name, "Raster fields are not supported."
So creating a separate table (using an insertcursor) for joining isn't a possibility?
Join Field—Data Management toolbox | ArcGIS Desktop
This join is permanent if memory serves
How to use an insertcursor on a Raster Field is pretty much my question. There's a Raster Field in a FC that I want populated with rasters. But, as I was reading how to access that type of field with a cursor it says it's not possible:
I was referring more to hyperlinking to the data or similar.
Adding raster datasets as attributes in a feature class—ArcGIS Pro | ArcGIS Desktop
is the remaining option, which would probably only be useful for a few
Dan,
Adding raster datasets as attributes is exactly what I need. But is there a way to automate this? I'm dealing with 1000s of rasters. I started out on this page and because there was no mention of Arcpy I moved on to looking into cursors.
Hello Jared,
Maybe the following thread can get you closer to what you are looking for: https://community.esri.com/thread/92354
I hope it helps!
For what it's worth, it looks like I can convert the rasters to a FGDB.
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'\pathTo\jpgs'</SPAN> <SPAN class="comment token">#Convert Multiple Raster Dataset to FGDB</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>RasterToGeodatabase_conversion<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"0100030.jpg;0100040.jpg"</SPAN><SPAN class="punctuation token">,</SPAN> r<SPAN class="string token">"\pathTo\Data.gdb"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Of course, this is just a sample. I'll have to set the script up to iterate through the directory and convert thousands of jpgs to the FGDB. But, after I do that I'm still stuck wondering how to get the raster into the Raster Field via Python.
Thanks to GeoNet, here's the work around I eventually came up with seeing that using Python to update a raster field isn't supported.
In the end I didn't use a raster field at all. I had a text field with a unique ID that matched the file name of JPGs in a directory. I used a script that updated another text field named 'Photo' with the full name of the JPG. Then I used arcpy.EnableAttachments_management(), which created a related table that can store rasters. Finally, I used arcpy.AddAttachments_management(), which populated the related table. Working with attachments was also helpful.
<SPAN class="string token">'''the purpose of this script is to update the 'Photo' field in the fc with the file path of the same name. '''</SPAN> <SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">,</SPAN> os ws <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'path\to\Projects\DOT_SignInventory\pics'</SPAN> jpgs <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN> <SPAN class="comment token"># empty dictionary</SPAN> <SPAN class="keyword token">for</SPAN> dirName<SPAN class="punctuation token">,</SPAN> subdirList<SPAN class="punctuation token">,</SPAN> fileList <SPAN class="keyword token">in</SPAN> os<SPAN class="punctuation token">.</SPAN>walk<SPAN class="punctuation token">(</SPAN>ws<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> fname <SPAN class="keyword token">in</SPAN> fileList<SPAN class="punctuation token">:</SPAN> jpgs<SPAN class="punctuation token">[</SPAN>fname<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>dirName<SPAN class="punctuation token">,</SPAN>fname<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> jpg <SPAN class="keyword token">in</SPAN> jpgs<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>jpg<SPAN class="punctuation token">)</SPAN> fc <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'path\to\Projects\DOT_SignInventory\Data2.gdb\WCDOT_Signs'</SPAN> fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'OID@'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Post_Number'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Photo'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> fields<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> jpgs<SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN> cursor<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">except</SPAN> KeyError<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"No photo for: {}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">del</SPAN> cursor<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
