dojo.require("esri.tasks.query"); function init() { var queryTask = new esri.tasks.QueryTask("http://sampleserver5.arcgisonline.com/ArcGIS/rest/services/Energy/Geology/MapServer/1"); var query = new esri.tasks.Query(); query.objectIds = [1]; query.outFields = ["*"]; queryTask.execute(query, function(featureSet) { var domains = []; var requestHandle = esri.request({ url: "http://sampleserver5.arcgisonline.com/ArcGIS/rest/services/Energy/Geology/FeatureServer/1", content: {f:"json"}, callbackParamName:"callback", load: function(res){ dojo.forEach(res.fields,function(f){ if (f.domain != null) { domains[f.name] = f.domain.codedValues; } }); dojo.forEach(featureSet.features,function(f) { for(attr in f.attributes) { if (attr in domains) { dojo.forEach(domains[attr],function(d) { if (d.code == f.attributes[attr]) f.attributes[attr] = d.name; }); } } }); console.log(featureSet.features); }, error: function(res){ console.log(res); } }, {useProxy:false}); },function(err){ console.log(err); }); } dojo.addOnLoad(init);
Looking forward to see what you come up with. This service has several layers with coded value domains: http://sampleserver5.arcgisonline.com/ArcGIS/rest/services/Energy/Geology/MapServer
org.mymanatee.common.util.getAliasDomainFormat=function(layerdesc, fieldName, field_val){ dojo.forEach(layerdesc.fields, dojo.hitch(this, function(ldf){ if(ldf.name==fieldName){ //replace with aliases fieldName = ldf.alias; // alert(ldf.name+" : "+ldf.type); if(ldf.type=="esriFieldTypeDate"){ // alert(ldf.type); field_val= dojo.date.locale.format(new Date(field_val), {datePattern: "MM/dd/yyyy"}); // alert(field_val); } if(ldf.type=="esriFieldTypeDouble"){ // alert(ldf.type); field_val= dojo.number.format(field_val,{places: 2 }); // alert(field_val); } if(ldf.domain){ dojo.forEach(ldf.domain.codedValues, dojo.hitch(this, function(domain){ if(field_val==domain.code){ field_val=domain.name; } })); } } })); return [fieldName,field_val]; }
org.mymanatee.common.util.getLayerDesc=function(url){ var desc; var layerurl= ""+url.replace("http://home.intranet","")+"/?f=json"; layerurl= ""+layerurl.replace("http://www.mymanatee.org",""); var params = { url: layerurl, handleAs: "json", sync: true }; var deferred =dojo.xhrGet(params); desc= deferred.results[0]; return desc; }
The general workflow would be:use esri.request() to get your layer's metadatakeep track of fields with domainsbuild an object for each field with a domain to map coded values to actual valuesexecute a querywhen processing the query results, map the coded values from the attributes to actual values
