During the ESRI UC at the WebApp Builder Island, staff showed off a new Dashboard Widget. When will that be available to use?
The Dashboard theme is now available.
Dashboard—All the widgets in the panel open simultaneously when the app starts. It is designed to visualize widgets and their communication directly. You can modify the predefined layout by adding or removing grids, or resizing the grids in the panel. By default, most on-screen widgets are turned off except the Home, Zoom Slider, and Full Screen widgets. Optionally, you can turn on the Header widget to display the logo, the app name, and links.
Hi Todd,
Just to add onto Ken's post:
- the Dashboard theme was added to Web AppBuilder embedded in ArcGIS Online in the June 2017 update;
- the Dashboard theme was added to Web AppBuilder Developer Edition v2.5, released on July 19th.
It is not currently available in Web AppBuilder embedded in Portal for ArcGIS yet. It will be added in a future ArcGIS Enterprise release. But you can use Web AppBuilder Developer Edition v2.5 with your Portal instance.
Hope this helps,
Is there a way to either import the Operations Dashboard widgets (gauge, indicator, etc.) into Web App Builder or vise versa.. import a map (with it's widgets) made in web app builder into the Operations Dashboard app? The incident analysis app. that is available in the web app. builder is not available in Operations Dashboard. Using the incident analysis app. is the only way I can figure out how to select by location to get number of features within an incident area on the fly.
Hi Molly,
The data visualization elements from Operations Dashboard for ArcGIS cannot be "imported" into a Web AppBuilder for ArcGIS app, because they were not designed as widgets. However, you could technically "add" a Web AppBuilder app into Operations Dashboard for ArcGIS - although the process is a workaround and not an official workflow.
> ... is the only way I can figure out how to select by location to get number of features within an incident area on the fly
Have you looked at the action functionality in Operations Dashboard? You could select a feature in the map element, then have other elements filter their data content based on the selection.
Actions—Operations Dashboard for ArcGIS | ArcGIS
Hey Derek - do you have any examples the workaround whereby a Web AppBuilder app is "added" into Operations Dashboard?
Is the Dashboard Theme in WAB capable of exporting to csv, etc? I’m using Portal 10.6.1 and it does not look like the Operations Dashboard offers any type of exporting yet so I’m curious if I need to rebuild my dashboard in WAB dashboard theme to get the best of both worlds
Hi Josh,
Sorry for the late reply, I've been out on business travel recently and missed the email notification for this thread.
I think you can add an Attribute Table widget in one of the dashboard theme 'containers', which would allow you to export data to CSV.
