Hi hawkeye81xYour solution is in ASP.Net. Do you think we can apply it with Flex (API)I have a feeling it is not possible to consume a SOAP service.Quote extracted from http://resources.esri.com/help/9.3/a...soap/index.htm"Developer environments, such as .NET or Java, provide SOAP toolkits to automate the process of generating a set of local, native classes for a consumer"Is it possible in Flex?
I'm sorry, i forgot images specificationsSame areaSame image format pngsame dpi 300thanks
Thank you very much hawkeye81x for information, I understand better nowLast question: Does it requires ArcGIS is installed on the server?Thanks again
