I have a shapefile where I have polylines and their fields are:
- length
- area into which they fall in
Now I need 3 longest lines from each area. I have 3 areas and 50 polylines, so I should get 3*3=9 records as a result. What I try to do is:
<SPAN class="keyword token">import</SPAN> arcpy
myFile <SPAN class="operator token">=</SPAN> somePath
sql <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'TOP 3'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ORDER BY "length" DESC GROUP BY "area_id" '</SPAN><SPAN class="punctuation token">)</SPAN>
cursor <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>myFile <SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">,</SPAN> None<SPAN class="punctuation token">,</SPAN> None<SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">,</SPAN> sql<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">with</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> r <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> r<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I get all of 50 records here. The same happens when I set `sql` to just `('TOP 1', None) or anything else.
Is the syntax wrong here?
