I have now finished adding Auto Add to Working Set TOC on Visible Checkbox Check in other TOC Ability to add to the Working Set TOC by drag and drop from other TOC A button to remove a layer from the Working Set TOC A Save Current Working Set TOC feature that saves the current state to a local txt file A Load a Saved Working Set TOC feature that loads a saved TOC state from a local txt fileI will give the code changes required if anyone wants them. It has not been cleaned up at all.Thanks for all the help.
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
