<SPAN class="keyword token">var</SPAN> layerURL <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2F172.20.25.165%3A6080%2Farcgis%2Frest%2Fservices%2FCrime2018%2FFeatureServer%2F" target="_blank">http://172.20.25.165:6080/arcgis/rest/services/Crime2018/FeatureServer/</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//querys the crimes layer for all burglaries</SPAN>
<SPAN class="keyword token">var</SPAN> burgresultsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> burgQsym <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//creates the symbol for burglaries query</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple-marker"</SPAN><SPAN class="punctuation token">,</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"green"</SPAN><SPAN class="punctuation token">,</SPAN>
style<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"triangle"</SPAN><SPAN class="punctuation token">,</SPAN>
size<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">8</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">/*alert(layerURL);*/</SPAN>
<SPAN class="keyword token">var</SPAN> qTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>url <SPAN class="punctuation token">:</SPAN> layerURL<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> burgQuery <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
burgQuery<SPAN class="punctuation token">.</SPAN>returnGeometry <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> fieldBoys <SPAN class="operator token">=</SPAN> burgQuery<SPAN class="punctuation token">.</SPAN>outFields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Offense"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Location"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">/*alert(fieldBoys);*/</SPAN>
burgQuery<SPAN class="punctuation token">.</SPAN>where <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Offense = Burglary"</SPAN><SPAN class="punctuation token">;</SPAN>
qTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>burgQuery<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
qTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">executeForCount</SPAN><SPAN class="punctuation token">(</SPAN>burgQuery<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN></SPAN>
