<?xml version="1.0" encoding="utf-8"?> <!-- //////////////////////////////////////////////////////////////////////////////// // // Copyright (c) 2010 ESRI // // All rights reserved under the copyright laws of the United States. // You may freely redistribute and use this software, with or // without modification, provided you include the original copyright // and use restrictions. See use restrictions in the file: // <install location>/License.txt // //////////////////////////////////////////////////////////////////////////////// --> <viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:viewer="com.esri.viewer.*" x="600" y="300" widgetConfigLoaded="init()"> <fx:Style> .PrintBox { color: #000000; /* for the printed page */ } </fx:Style> <fx:Script> <![CDATA[ import mx.controls.Alert; import mx.graphics.ImageSnapshot; import mx.printing.FlexPrintJob; import mx.printing.FlexPrintJobScaleType; //added to get widgets to print on map LJA import com.esri.viewer.ViewerContainer; //end add import spark.components.Label; import spark.components.VGroup; import spark.primitives.BitmapImage; [Bindable] private var title:String; [Bindable] private var subtitle:String; private var copyright:String = ""; //labels [Bindable] private var titleLabel:String; [Bindable] private var subtitleLabel:String; [Bindable] private var submitLabel:String; private function init():void { if (configXML) { title = configXML.title[0] || getDefaultString("printTitle"); subtitle = configXML.subtitle[0] || getDefaultString("printSubtitle"); copyright = configXML.copyright[0] || getDefaultString("printCopyright"); //labels titleLabel = configXML.labels.titlelabel[0] || getDefaultString("printTitleLabel"); subtitleLabel = configXML.labels.subtitlelabel[0] || getDefaultString("printSubtitleLabel"); submitLabel = configXML.labels.submitlabel[0] || getDefaultString("printSubmitLabel"); } } private function printMap():void { var zoomSliderVisibleBeforePrint:Boolean; if (map.zoomSliderVisible) { map.zoomSliderVisible = false; zoomSliderVisibleBeforePrint = true; } var printJob:FlexPrintJob = new FlexPrintJob(); printJob.printAsBitmap = false; if (printJob.start()) { var h:Number = printJob.pageHeight; var w:Number = printJob.pageWidth; //VGROUP var printBox:VGroup = new VGroup(); printBox.styleName = "PrintBox"; printBox.width = map.width; this.addChild(printBox); // add now to workaround https://bugs.adobe.com/jira/browse/SDK-26906 try { //TITLE var printTitle:Label = new Label(); printTitle.text = txtTitle.text; // TODO: make fontsize specified in stylename overwrite this fontSize printTitle.setStyle("fontSize", h / 12); printTitle.percentWidth = 100; printBox.addElement(printTitle); //SUBTITLE var printSubtitle:Label = new Label(); printSubtitle.text = txtSubtitle.text; // TODO: make fontsize specified in stylename overwrite this fontSize printSubtitle.setStyle("fontSize", h / 24); printSubtitle.percentWidth = 100; printBox.addElement(printSubtitle); //MAP //add to capture widgets LJA var bmpMap:BitmapData = ImageSnapshot.captureBitmapData(ViewerContainer.getInstance()); //var bmpMap:BitmapData = ImageSnapshot.captureBitmapData(map); var printImg:BitmapImage = new BitmapImage(); printImg.smooth = true; printImg.source = bmpMap; printBox.addElement(printImg); //COPYRIGHT var now:Date = new Date(); var printCopy:Label = new Label(); printCopy.text = copyright + " " + now.toLocaleString() + "."; // TODO: make fontsize specified in stylename overwrite this fontSize printCopy.setStyle("fontSize", h / 48); printCopy.percentWidth = 100; printBox.addElement(printCopy); //PRINT printJob.addObject(printBox, FlexPrintJobScaleType.SHOW_ALL); printJob.send(); bmpMap.dispose(); } catch (error:Error) { Alert.show(error.toString(), wTemplate.widgetTitle); } finally { this.removeChild(printBox); } } if (zoomSliderVisibleBeforePrint) { map.zoomSliderVisible = true; } } ]]> </fx:Script> <viewer:WidgetTemplate id="wTemplate" width="300" height="180" minHeight="168" minWidth="280"> <mx:Form id="frmPrint" width="100%" height="100%" paddingBottom="0" verticalScrollPolicy="off"> <mx:FormItem width="100%" label="{titleLabel}"> <s:TextInput id="txtTitle" width="100%" text="{title}"/> </mx:FormItem> <mx:FormItem width="100%" label="{subtitleLabel}"> <s:TextInput id="txtSubtitle" width="100%" text="{subtitle}"/> </mx:FormItem> <s:HGroup width="100%" horizontalAlign="center"> <s:Button click="printMap()" label="{submitLabel}"/> </s:HGroup> </mx:Form> </viewer:WidgetTemplate> </viewer:BaseWidget>
I need to print the legend widget window when I use Print Widget. Although the legend widget is open when I send the print job, it does not show up on the final printed map. Should I use something like printBox.addElement (LegendWidget)? Thanks!
