Hello,
I've installed portal for ArcGIS 10.4.1 on a new server, with web adaptor and CA certificate.
While I'm trying to add a group, I get this message "unable to create the group at this time".
Any ideas?
Thanks
Ofra
A known bug
Use this patch Portal for ArcGIS Home Application Upload Patch
I'm having trouble with the patch suggested, is there a patch for the patch?
Make sure you install the appropriate version of patch. Are you using Portal for ArcGIS 10.4.1?
Yes I am. For now I worked around by using Internet Explorer to create a group, but it would be nice for our users to be able to create their own. I've tried it on two separate Windows 7 machines, same result. Any ideas?
Should I be installing this on the user or server machine?
The one where Portal for ArcGIS is installed.
Ok well I was able to successfully install on portal machine, which is the server, but even after closing and reopening Chrome, logging out and into portal, I get the same error message.
I'm having the same issue. We're running 10.4.1, I'm running Chrome 55, installed the above patch and still can't add groups.
Jennie:
Have you tried it with IE?
Same result?
Perhaps check the permissions of the arcgisportal folder?
(Solved) - Installed a new patch ArcGIS-1041-PFA-SEC2017U1-Patch-linux.tar
Hi guys
I installed Portal for ArcGIS Home Application Upload Patch for linux today, my Portal stopped to work after that.
It was created a extra folder called linux.portal at Portal installation Folder.
I run portaldiag to check the requirements and now I got a Warning Diag_26
DIAG000: Check for installation as root [PASSED] DIAG001: Check for 64-bit architecture [PASSED] DIAG002: Check OS version [PASSED] DIAG003: Check hostname for invalid characters [PASSED] DIAG005: Check system limits [PASSED] DIAG004: Check installed packages [PASSED] DIAG006: Check OS patches [PASSED] DIAG016: Check Portal for ArcGIS ports [PASSED] DIAG024: Check localhost resolution [PASSED] DIAG020: Check hostname IP address mismatches [PASSED] DIAG026: Check processes of Portal for ArcGIS core services [WARNING] DIAG028: Check data directory [PASSED] DIAG029: Check file system type [PASSED]
------------------------------------------------------------------------There were 0 failure(s) and 1 warning(s) found:
WARNINGS:------------------------------------------------------------------------
*** DIAG026: One or more core services was not started. Start Portalfor ArcGIS by running the startportal.sh script or restart Portal forArcGIS if it is already started.
Any idea to help me? Reinstall Portal will be terrible for me
Thank you.
