# POS transect with measures posArray = arcpy.Array() for transit in dPOS.keys(): for mrk in dPOS[transit]: ta,tb = trans(mrk[0],mrk[1]) posArray.add(arcpy.Point(ta,tb,mrk[2],mrk[3])) rowPOS = curPOS.newRow() rowPOS.mark = transit.upper() rowPOS.plotid = plotid rowPOS.plotmark = plotid + transit.upper() rowPOS.shape = posArray curPOS.insertRow(rowPOS) posArray.removeAll()
# fillDonut.py # frequent forum request to fill holes # use an Update Cursor to edit polys with donuts # 22 May 2010 # Kim Ollivier kimo@ollivier.co.nz # (c) Creative Commons 3.0 (Attribution) # Method # ------ # Polygon features are stored as: # [[pnt,pnt,pnt,pnt,,pnt,pnt,pnt,pnt][pnt,pnt,pnt,pnt]] # Parts are separate lists inside the feature object array # null point in a part indicates donut ring(s) follow # So just step through and truncate at first null pnt per part, # re-assemble parts into a polygon # Update feature if a donut found, otherwise continue # Input is a layer so can use selection in Arcmap # could also put on menu at ArcMap 10 # can be back-ported to 9.3 # 4 June 2010 # added iter lambda function for part array because isn't interable # cleared polyOuter buffer earlier to fix logic for multiple parts import arcpy,sys def filldonut(inlay) : '''Edits a layer in-place fills all features with donuts requires a layer to honour selected features ''' desc = arcpy.Describe(inlay) shapefield = desc.ShapeFieldName rows = arcpy.UpdateCursor(inlay) n = 0 polyGeo = arcpy.Array() # to hold edited shape polyOuter = arcpy.Array() # to hold outer ring for row in rows: feat = row.getValue(shapefield) qInterior = False for partNum in range(feat.partCount) : part = feat.getPart(partNum) for pt in iter(lambda:part.next(),None) : # iter stops on null pt polyOuter.append(pt) if part.count > len(polyOuter) : qInterior = True polyGeo.append(polyOuter) # reassemble each part polyOuter.removeAll() # ready for next part if qInterior : # in any part of this feature, otherwise skip update n+=1 row.setValue(shapefield,polyGeo) rows.updateRow(row) polyGeo.removeAll() del rows,row msg = "Features with interior ring filled "+str(n) arcpy.AddMessage(msg) arcpy.AddMessage("Refresh view to see donuts disappear!") #---------------------------------------------------- if __name__ == '__main__' : inlay = sys.argv[1] # arcpy.GetParameterAsText(0) desc = arcpy.Describe(inlay) if desc.shapetype != 'Polygon' : arcpy.AddError(inlay + " Not a polygon class") else : filldonut(inlay) arcpy.RefreshGraphics()
... basically Calc field X to field M and Calc field Y to field Z.
import arcpy input_fc = r"C:\points_to_XYMZ\f.gdb\poly_fc_zm" g = arcpy.Geometry() geometry_list = arcpy.CopyFeatures_management(input_fc, g) for geom in geometry_list: c = geom.centroid print c.X, c.Y, c.Z, c.M
