Hello,Curious if the Query Task will return overlapping polygons in the same feature layer? I know the Identify Task will do this, but I am working with data that contain relationship classes to SDE tables. From what I've read, the Identify Task is not able to reveal related data, unless I am mistaken.What I am trying to do is select features using a box and returning related attributes to a DataGrid table. So far, I've only been able to pass the top most polygon within the same feature layer and not any underlying polgyons.Your help and suggestions are greatly appreciated!Trent
<script type="text/javascript"> dojo.require("esri.map"); dojo.require("esri.layers.FeatureLayer"); dojo.require("esri.tasks.query"); dojo.require("dojox.grid.DataGrid"); dojo.require("dojo.data.ItemFileReadStore"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); var selectionToolbar, featureLayer, grid, store, selectionLayer; function init() { var initialExtent = new esri.geometry.Extent({ "xmin": -107.75, "ymin": 30, "xmax": -105, "ymax": 40, "spatialReference": { "wkid": 4269} }); var map = new esri.Map("map", { extent: esri.geometry.geographicToWebMercator(initialExtent), slider: true, nav: true }); map.addLayer(new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer")); var imageParams = new esri.layers.ImageParameters(); imageParams.layerIds = [0]; imageParams.layerOption = esri.layers.ImageParameters.LAYER_OPTION_SHOW; var dynamicLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis1ace/ArcGIS10/rest/services/MRG_select_box_test/MapServer", { imageParameters: imageParams }); map.addLayer(dynamicLayer); var selectionLayer = new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([255, 255, 0, 0.5])); selectionLayer.setOutline(new esri.symbol.SimpleLineSymbol("dashdot", new dojo.Color([255, 0, 0]), 2)); var content = "<b>Feature ID</b>: ${FeatureID}"; var infoTemplate = new esri.InfoTemplate("${FeatureID}", content); featureLayer = new esri.layers.FeatureLayer("http://gis1ace/ArcGIS10/rest/services/MRG_select_box_test/MapServer/0", { mode: esri.layers.FeatureLayer.MODE_SELECTION, infoTemplate: infoTemplate, outFields: ["*"] }); featureLayer.setSelectionSymbol(selectionLayer); map.addLayer(featureLayer); dojo.connect(map, "onLoad", initSelectToolbar) dojo.connect(featureLayer, "onSelectionComplete", findRelatedRecords); } function initSelectToolbar(map) { selectionToolbar = new esri.toolbars.Draw(map); var selectQuery = new esri.tasks.Query(); dojo.connect(selectionToolbar, "onDrawEnd", function (geometry) { selectionToolbar.deactivate(); selectQuery.geometry = geometry; featureLayer.selectFeatures(selectQuery, esri.layers.FeatureLayer.SELECTION_NEW); }); } for (var i = 0, il = featureSet.features.length; i < il; i++) { //Get the current feature from the featureSet. var graphic = featureSet.features; //Relationship query function findRelatedRecords(features) { var relatedDocQuery = new esri.tasks.RelationshipQuery(); relatedDocQuery.outFields = ["*"]; relatedDocQuery.relationshipId = 1; relatedDocQuery.objectIds = [features[0].attributes.OBJECTID]; featureLayer.queryRelatedFeatures(relatedDocQuery, function (relatedRecords) { var fset = relatedRecords[features[0].attributes.OBJECTID]; var items = dojo.map(fset.features, function (feature) { return feature.attributes; }); //Create data object to be used in store var data = { identifier: "OBJECTID", //This field needs to have unique values label: "OBJECTID", //Name field for display. Not pertinent to a grid but may be used elsewhere. items: items }; //Create data store and bind to grid. store = new dojo.data.ItemFileReadStore({ data: data }); grid.setStore(store); grid.setQuery({ OBJECTID: '*' }); }); } dojo.addOnLoad(init); </script>
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
