I'm trying to format the value of a field for display in an infoTemplate but nothing is happening; it appears as though the function is not being called. I used the example here as a guide, see the compare() function.I simply want to format the text to display either Gbps or Tbps based on the value of the field. The relevant field is called "Capacity_G" and I put the console.log statements in there to test whether the function was executing; it is not. var infoTemplate = new InfoTemplat(); infoTemplate.setTitle("<b>Cable: ${NAME}</b>"); infoTemplate.setContent("Capacity: ${CAPACITY_G:formatCapacity}"); function formatCapacity(value){ console.log("LALALALALAA"); var cap = ""; //1Tb = 1024Gb if (value >= 1024){ cap = value/1024 + "Tbps"; } else { cap = value + "Mbps"; } console.log("LALALALALALALA"); return cap; }
What have I done wrong? The text in the resulting popup appears unmodified, exactly as it is in the attributes of the data.
