Is it possible to add rotating images to the banner page? How would I go about doing this?
Best way to do this today is in an Iframe (you'd have to write a little HTML/CS/Javascript to do it and host the code somewhere).
We'll take this request under consideration. Are you more interested in having the banner card rotate images or an entire row background image having a collection that rotate? Something else?
I think the answer is just "yes" ... adding different sorts of content animation and cycling seems engaging and useful for different purposes.
Ok. I dug up code to create an example. Sort of.
-THIS IS NOT ORIGINALLY MY CSS CODE-
What we want is a "pure CSS" slideshow/carousel.
I implemented this here: TechDemo
I took the CSS code from: https://codepen.io/dudleystorey/pen/kFoGw
Modified slightly because Hub filtered out the use of the author's original "figure" and "figcaption" tags. I pointed it at some Pexels content which is free.
Note, too, that this is built to show five images. The @keyframes definition and a number of other definitions in the code are built around a five image carousel.
<SPAN class="language-css style token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="atrule token"><SPAN class="rule token">@import</SPAN> <SPAN class="url token">url(https://fonts.googleapis.com/css?family=Istok+Web)</SPAN><SPAN class="punctuation token">;</SPAN></SPAN> <SPAN class="atrule token"><SPAN class="rule token">@keyframes</SPAN> slidy</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="selector token">0%</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN> 0%<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">20%</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN> 0%<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">25%</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN> -100%<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">45%</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN> -100%<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">50%</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN> -200%<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">70%</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN> -200%<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">75%</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN> -300%<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">95%</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN> -300%<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">100%</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN> -400%<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">div.figure</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">margin</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">background</SPAN><SPAN class="punctuation token">:</SPAN> #101010<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">font-family</SPAN><SPAN class="punctuation token">:</SPAN> Istok Web, sans-serif<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">font-weight</SPAN><SPAN class="punctuation token">:</SPAN> 100<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">div#captioned-gallery</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 100%<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">overflow</SPAN><SPAN class="punctuation token">:</SPAN> hidden<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">div.figure_slider</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">position</SPAN><SPAN class="punctuation token">:</SPAN> relative<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 500%<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">font-size</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">animation</SPAN><SPAN class="punctuation token">:</SPAN> 30s slidy infinite<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">margin</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">background</SPAN><SPAN class="punctuation token">:</SPAN> #101010<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">font-family</SPAN><SPAN class="punctuation token">:</SPAN> Istok Web, sans-serif<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">font-weight</SPAN><SPAN class="punctuation token">:</SPAN> 100<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">div.figure_slider_figure</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 20%<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN> auto<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN> inline-block<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">position</SPAN><SPAN class="punctuation token">:</SPAN> inherit<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">margin</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">background</SPAN><SPAN class="punctuation token">:</SPAN> #101010<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">font-family</SPAN><SPAN class="punctuation token">:</SPAN> Istok Web, sans-serif<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">font-weight</SPAN><SPAN class="punctuation token">:</SPAN> 100<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">img.figure_slider_img</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 100%<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN> 300px<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">div.figure_slider_figure_figcaption</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">position</SPAN><SPAN class="punctuation token">:</SPAN> absolute<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">bottom</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">background</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="token function">rgba</SPAN><SPAN class="punctuation token">(</SPAN>0,0,0,0.4<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="property token">color</SPAN><SPAN class="punctuation token">:</SPAN> #fff<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 100%<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">font-size</SPAN><SPAN class="punctuation token">:</SPAN> 2rem<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">padding</SPAN><SPAN class="punctuation token">:</SPAN> .6rem<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">margin</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">background</SPAN><SPAN class="punctuation token">:</SPAN> #101010<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">font-family</SPAN><SPAN class="punctuation token">:</SPAN> Istok Web, sans-serif<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">font-weight</SPAN><SPAN class="punctuation token">:</SPAN> 100<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>captioned-gallery<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_figure<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>img</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_img<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://images.pexels.com/photos/2537598/pexels-photo-2537598.jpeg?auto<SPAN class="punctuation token">=</SPAN>compress&cs<SPAN class="punctuation token">=</SPAN>tinysrgb&dpr<SPAN class="punctuation token">=</SPAN>2&h<SPAN class="punctuation token">=</SPAN>300&w<SPAN class="punctuation token">=</SPAN>940<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">alt</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_figure_figcaption<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>Hobbiton, New Zealand<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_figure<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>img</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_img<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://images.pexels.com/photos/3097112/pexels-photo-3097112.jpeg?auto<SPAN class="punctuation token">=</SPAN>compress&cs<SPAN class="punctuation token">=</SPAN>tinysrgb&dpr<SPAN class="punctuation token">=</SPAN>2&h<SPAN class="punctuation token">=</SPAN>300&w<SPAN class="punctuation token">=</SPAN>940<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">alt</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_figure_figcaption<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>Wanaka, New Zealand<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_figure<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>img</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_img<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://images.pexels.com/photos/2873671/pexels-photo-2873671.jpeg?auto<SPAN class="punctuation token">=</SPAN>compress&cs<SPAN class="punctuation token">=</SPAN>tinysrgb&dpr<SPAN class="punctuation token">=</SPAN>2&h<SPAN class="punctuation token">=</SPAN>300&w<SPAN class="punctuation token">=</SPAN>940<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">alt</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_figure_figcaption<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>Utah, United States<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_figure<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>img</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_img<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://images.pexels.com/photos/3121976/pexels-photo-3121976.jpeg?auto<SPAN class="punctuation token">=</SPAN>compress&cs<SPAN class="punctuation token">=</SPAN>tinysrgb&dpr<SPAN class="punctuation token">=</SPAN>2&h<SPAN class="punctuation token">=</SPAN>300&w<SPAN class="punctuation token">=</SPAN>940<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">alt</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_figure_figcaption<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>Bryce Canyon, Utah, United States<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_figure<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>img</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_img<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://images.pexels.com/photos/2559175/pexels-photo-2559175.jpeg?auto<SPAN class="punctuation token">=</SPAN>compress&cs<SPAN class="punctuation token">=</SPAN>tinysrgb&dpr<SPAN class="punctuation token">=</SPAN>3&h<SPAN class="punctuation token">=</SPAN>300&w<SPAN class="punctuation token">=</SPAN>940<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">alt</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>figure_slider_figure_figcaption<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>Bryce Canyon, Utah, United States<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
This is wonderful! Thank you so much for sharing!
