Hi Alex,Take a look at this thread. There is an example where you can select a graphic and export it to a shapefile through the infoWindow.
Hi Jake,
I am not able to click on the link you mention in your reply to Alex. I tried viewing this in the latest version of Chrome as well as IE 11 and the links are just not clickable although they look like links, i mean they are blue (or greyish blue, cant really tell) in color. Can you please provide the full link?
Hi Anand,
Looks like the migration to GeoNET broke some hyperlinks. Below is the code:
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title></title> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body, #mapDiv { padding:0; margin:0; height:100%; } #loading { display: none; vertical-align: middle; } </style> <script src="http://js.arcgis.com/3.8/"></script> <script> var map, featureLayer, gp; require([ "esri/map", "esri/config", "esri/layers/FeatureLayer", "esri/InfoTemplate", "esri/tasks/FeatureSet", "esri/geometry/Extent", "esri/layers/GraphicsLayer", "esri/tasks/Geoprocessor", "dijit/form/Button", "dojo/parser", "dijit/registry", "dojo/dom", "dojo/on", "dojo/dom-style", "dojo/domReady!" ], function( Map, esriConfig, FeatureLayer, InfoTemplate, FeatureSet, Extent, GraphicsLayer, Geoprocessor, Button, parser, registry, dom, on, domStyle ) { parser.parse(); esriConfig.defaults.io.proxyUrl = "proxy.ashx"; var loading = dom.byId("loading"); map = new Map("mapDiv", { basemap: "streets", center: [-117.1625, 32.7150], zoom: 13 }); var infoTemplate = new InfoTemplate("Details", "<tr>OBJECTID: <td>${objectid}</tr></td><br><br><button id='button' dojoType='dijit.form.Button'>Export</button>"); featureLayer = new FeatureLayer("http://sampleserver4.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/Incident_Data_Extraction/MapServer/2",{ mode: FeatureLayer.MODE_ONDEMAND, infoTemplate: infoTemplate, outFields: ["*"] }); map.addLayer(featureLayer); gp = new Geoprocessor("http://sampleserver4.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/Incident_Data_Extraction/GPServer/Extract%20Data%20Task"); gp.setOutSpatialReference({ wkid : 102100 }); on(map.infoWindow, "show", function(){ on(dom.byId("button"), "click", extractData); }) function pointToExtent(map, pointX, pointY, tolerance){ var xmin = pointX - tolerance; var ymin = pointY - tolerance; var xmax = pointX + tolerance; var ymax = pointY + tolerance; return new Extent(xmin, ymin, xmax, ymax, map.spatialReference) } function extractData() { var extent = pointToExtent(map, map.graphics.graphics[0].geometry.x, map.graphics.graphics[0].geometry.y, 10); map.graphics.add(extent); var featureSet = new FeatureSet(); var features = []; features.push(map.graphics.graphics[0]); featureSet.features = features; var params = { "Layers_to_Clip" : ["Incident Areas"], "Area_of_Interest" : featureSet, "Feature_Format" : "Shapefile - SHP - .shp" }; domStyle.set(loading, "display", "inline-block"); gp.submitJob(params, completeCallback, statusCallback, function(error) { alert(error); domStyle.set(loading, "display", "none"); }); } function completeCallback(jobInfo){ if ( jobInfo.jobStatus !== "esriJobFailed" ) { gp.getResultData(jobInfo.jobId, "Output_Zip_File", downloadFile); } } function statusCallback(jobInfo) { var status = jobInfo.jobStatus; if ( status === "esriJobFailed" ) { alert(status); domStyle.set("loading", "display", "none"); } else if (status === "esriJobSucceeded"){ domStyle.set("loading", "display", "none"); } } function downloadFile(outputFile){ var theurl = outputFile.value.url; window.location = theurl; } }); </script> </head> <body> <div id="mapDiv"> <img id="loading" src="images/loading.gif"> </div> </body> </html>
Thanks Jake this helps.
Can you please take a look at a related question I posted and let me know if you have any ideas/suggestions?
https://community.esri.com/message/397744?sr=search&searchId=f7f71b54-ca93-49f3-893b-8a8a41937623&searchIndex=0#397744
