Dear Friends,Has anyone tested the WPS functionality in 10.1 using non ESRI clients? What are the experiences? I have tested with QGIS WPS plugin, uDig WPS client and Jump WPS clients. In all of them I can access the service metadata and ProcessDescriptions but none is able to execute processes. Your ideas and insight on this issue are welcome. Thank you. Best Regards,Timothy GitumaIn der Au 16B, Zimmer Nr.220170327, Stuttgart.Tel: +004917668674686
Hi Yingqi,Thanks for sharing. Well, I have decided to build my own client based on open layers but maybe I will also look into the QGIS WPS plugin as you have suggested. For now am just using an HTTP client to test the execution of my processes. While editing XML is not my cup of tea, it works without a problem. On a different note, is there a way of accessing the WPS processes in ArcMap/ArcCatalog applications like we do with other OGC services like WMS, WCS, WFS? I'm interested in combining WPS services from different providers in a geoprocess model using modelbuilder.
Hi Tim,
I know it has been a few years and a few releases, but I am not having the same issue with Execute at ArcServer 10.3.1
I am trying to use CuRL to post an XML document with an Input Feature Set Polygon, but with no luck. Could you possibly post an example XML that you have successfully executed against an ArcServer WPS service?
Thanks so much!
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
