I just created a new mosaic dataset with ArcMap 10.2.2. Added the rasters - Mr. Sid. Built the Overviews. But a hole appears in one area. Any ideas on how to fix it?
Hi Michael,
If you keep zooming into the area with No Data are you able to see the pixels eventually? This would indicate an issue with the overviews. Can you provide a screen shot of what you are seeing?
Yes when I zoom in I can see the images. I it definitely a problem with the overviews.
Did you find a solution to this? I have the same issue.
No I never did. Fortunately it was not in a critical area.
Thanks. I guess that is how I'm going to leave it as well.
