Is there “export to graphics” tool in the model builder of ArcGIS Pro,
I couldn’t figure out if “export to graphics” tool is available in the model builder of ArcGIS Pro,
Yes, on the ModelBuilder contextual tab, the Model Group, click the Export dropdown and you'll see "Export to Graphic"
Your journey to discovering that things aren't a direct conversion between ArcMap and Pro will be a long one... you have found another example
https://community.esri.com/community/arcgis-ideas?sr=search&searchId=b86f29f3-e177-4cb2-8843-0fdd0d3cb136&searchIndex=0 or wait patiently are your only options
It is the need that leads me to highlight missing functions\tools in ArcGIS Pro. However, I prefer to check first with experts in the forum and see if there is a solution.
For me, I’m trying to work on ArcGIS Pro, as I get stuck with the issue of missing functions\tools, I get back to ArcMap
The best advice from someone that has been through at least 9 different GIS packages and countless other programming and application incarnations.
Then the first 4 of my 10 rules for a successful gis career when using software
I'm working with a BETA copy of Pro 2.1 and do not see the "export to graphics" command in the UI. One option is to use the Snipping Tool from the Windows OS and export to graphic that way. I'll be curious to see if FINAL Pro 2.1 has the "export to graphics" functionality.
All can I say is ridcilious tha it is stil not in ArcGIS Pro 2.3.3 !
Hi Jamal NUMAN,
Also, our request to all who have responded on this thread to take the survey: http:/bit.ly/esrimodelbuilder and give us feedback on the things you want to see improved or added in ModelBuilder. It helps us respond to the issues that all of you are facing in a more effective way.
Thanks!
You can follow this idea https://community.esri.com/ideas/16735-arcpro-export-model-as-image
i have already voted for the idea. I'm happy that it is in the production plan
Is the export tool already available in Pro 2.5?
Thanks Robert.
-Not all the files formats are there!
-Not sure how to dp the print setup. For example, I couldn’t know how to export to portrait A4
Hello Jamal,
Yes, the print set up and all file formats are not yet available in ArcGIS Pro. We will consider this in near future. I will update as soon as we bring this in our product plan.
Is "print setup" available in 3.0?
There is a nice tool bar in FME from which one can choose all the required settings for printing
Thanks for putting a smile on my face whilst looking for a way to export my model to jpeg (no clue why they removed that function, smh)! So curiousity ensued: What are your other rules? 😄
Hi all, Just checking: As off Arcgis Pro 3.0.1. there is still no export to graphic -> Jpeg, png, etc? I am wondering why? The work around at the moment is to export as .SVG, open in browser and save as image (jpg). Forgive me, but it seems silly to have export to graphic available, but to have SVG and PDF as only options.Any idea when this can/will be implemented?
Kind regards,C. ReidGIS Lecturer VHL University of Applied Sciences
