I have successfully inserted a link in a popup window, like this. Now how can I call a Feature action (Export to CSV, View in Attribute Table, etc.) on a click on that link?
Thanks!
Benedek,
It is as simple as calling code like this from your function:
<SPAN class="keyword token">var</SPAN> feature <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>mapManager<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getSelectedFeature</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> fs <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>features<SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN>feature<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> csvAct <SPAN class="operator token">=</SPAN> FeatureActionManager<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getInstance</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">getActionsByActionName</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ExportToCSV"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> csvAct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">onExecute</SPAN><SPAN class="punctuation token">(</SPAN>fs<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thank you, Robert!
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
