Does anyone know if you can create point symbology from the center coordinate of a line feature using arcade?
I'm currently working on this for polygon features.
Using:
POINT (Centroid(Geometry($feature)))<SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
But getting this error:
Execution Error:Cannot create Geometry in this SpatialReference. Engine is using a different spatial reference.<SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
I don't think you can use Arcade to visualize polylines as points. The error message seems to refer to the spatial reference. I did a simple test on a hosted feature that I published using the same spatial reference as the base map and it returned the point:
var geom = Geometry($feature); Console('\ngeom:' + geom); var line = Polyline(geom); Console('\nline:' + line); var cent = Centroid(line); Console('\ncent:' + cent); var pnt = Point(cent); Console('\npnt:' + pnt); return pnt;<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Which yields:
geom:{"paths":[[[-8414259.482734734,697445.4680427602],[-8414258.288406167,697445.4680427602],[-8414258.288406167,697457.4113284288]]],"spatialReference":{"wkid":102100,"latestWkid":3857}} line:{"paths":[[[-8414259.482734734,697445.4680427602],[-8414258.288406167,697445.4680427602],[-8414258.288406167,697457.4113284288]]],"spatialReference":{"wkid":102100,"latestWkid":3857}} cent:{"x":-8414259.482734734,"y":697445.4680427602,"spatialReference":{"wkid":102100,"latestWkid":3857}} pnt:{"x":-8414259.482734734,"y":697445.4680427602,"spatialReference":{"wkid":102100,"latestWkid":3857}} <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
So it returns the point, but the symbology will no be what you want (they will remain lines, and you will have an object for your symbology that you cannot actually use):
@XanderBakker,
In theory, if you use feature sets with this workflow could you use arcade on a separate point layer to represent the centroid of this line layer?
We're looking to do the same thing, but curious on your thoughts as we get started.
Thanks!
Hi @Amanda__Huber ,
So in the symbology profile, Arcade could return a geometry, but this is not something that is valid and that can be used to draw those features. Can you elaborate a bit more on what you have and what you want to get (and explain the why in this a bit more)?
I'm not sure if this will be helpful or not, but I'll post it anyway:
In similar situations where we don't have a Midpoint() function, such as in the St_Geometry spatial type in EGDBs, we've used the following hack:
Buffer the line and get the centroid of the resulting polygon. It's kind of like a "poor man's midpoint".
If I recall, that works ok. But I think I remember the point not being the exact midpoint of the line. I forget what the specific issue was. It's probably good enough for most use cases though...
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
