Hello,
I have noticed that when I extrude a geometry and use elevationInfo as "relative-to-ground" it will follow the elevation only for the points that defines this geometry.
Visually my problem is on the image bellow. The yellow geometry is a ring the is being extruded and it`s border can follow ground elevation, however there is a higher elevation between extremities that is piercing through.
I would like to know if this is a know issue, or if I am missing some configuration for my layer.
Thanks!!
