Hi There,
Hopefully someone can point me in the right direction with this, since I haven't been able to find the answer so far.
I have a python script that I run after the reconcile and post procedure to recreate the required child versions (simply for consistency and to save myself some time). However, it seems to take a really long time and the strange thing is that all of the versions take almost the exact same amount of time to create.
Would anyone be able to suggest what is at play here? Or provide an example of a similar script they may be using to do the same?
Here an sample from my script:
import sde_generate_connect_strings
sde_user_connect = sde_generate_connect_strings.generate_sde_user()
# create MAINTENANCE
print 'Create MAINTENANCE...'
logfile.write('Create MAINTENANCE...\n')
print 'Connection used is: ' + sde_user_connect
if sde_user_connect:
try:
arcpy.CreateVersion_management(sde_user_connect,'sde.DEFAULT', 'MAINTENANCE', 'PUBLIC')
print arcpy.GetMessages()
logfile.write(arcpy.GetMessages())
except:
print 'Oops! Exception...'
else:
print '* * * * * * * *'
print 'Database connection doesn\'t exist - failed to create MAINTENANCE'
print '* * * * * * * *'Thanks,
Warren
