<type 'exceptions.TypeError'>: unbound method removeAll() must be called with Array instance as first argument (got nothing instead)
import arcpy,os #Declare Variables mxd = arcpy.GetParameter(0) outLocation = arcpy.GetParameterAsText(1) outName= arcpy.GetParameterAsText(2)+".shp" outPath = os.path.join(outLocation,outName) featureList = [] ar=arcpy.Array #Export the table values to a string maps=mxd.exportToString() #Remove field delimiters maps = maps.replace("'",'').strip() arcpy.AddMessage(maps) maplist= maps.split(';') arcpy.AddMessage(maplist) #Cycle through list of maps for mapp in maplist: arcpy.AddMessage(mapp) mxd1 = arcpy.mapping.MapDocument(mapp) frames = arcpy.mapping.ListDataFrames(mxd1) #Cycle through the list for df in frames: #Creates a polygon object poly = arcpy.Polygon(ar([df.extent.lowerLeft, df.extent.lowerRight, df.extent.upperRight, df.extent.upperLeft]), df.spatialReference) featureList.append(poly) #Remove the array for the next polygon ar.removeAll(ar)
for df in frames: #Creates a polygon object poly = arcpy.Polygon(arcpy.Array([df.extent.lowerLeft, df.extent.lowerRight, df.extent.upperRight, df.extent.upperLeft]), df.spatialReference) featureList.append(poly) # All done
