C:\Temp>sdeservice -o list -i sql101 SDE service Information -------------------------------------------------------------------- RDBMS: SQLServer Name: ArcSde Service(sql101) SDEHOME: C:\Esri\arc101sql64-sp1\ArcSDE\sqlexe Datasource: laptopnaname Admin_database: sql101 Version: 10.1 Status: SERVICE_STOPPED
C:\Temp>sdeservice ESRI ArcSDE System Service Utility Fri Mar 22 14:55:40 2013 ------------------------------------------------------------------------- sdeservice -o create -d <ORACLE,SID|SQLSERVER,SQLSERVERINSTANCE| DB2,DB2INSTANCE|POSTGRESQL,PGINSTANCE| INFORMIX|COVERAGES> -p <SDE_DBA_Password> [-s <datasource>] [-i <service>] [-u <service_user>] [-n] [-H <sde_directory>] [-P <service_user_password>]
The database/SDE/ArcGIS Server environment is local.Havent changed the password yet, but did just try it with the -s option. Same error.
