import arcpy, sys mxd = arcpy.mapping.MapDocument("base.mxd") prjList = "q:/python/prj/" # Read in the coordinate system definition prj = arcpy.SpatialReference(prjList+sys.argv[1]+".prj") # Get the code (e.g. 2288 = "NAD_1983_StatePlane_California_VI_FIPS_0406_Feet") code = prj.PCSCode df = arcpy.mapping.ListDataFrames(mxd)[0] sr = df.spatialReference sr.PCSCode = code df.spatialRefence = sr mxd.save() del mxd
import arcpy, sys mxd = arcpy.mapping.MapDocument("base.mxd") prjList = "q:/python/prj/" # Read in the coordinate system definition prj = arcpy.SpatialReference(prjList+sys.argv[1]+".prj") df = arcpy.mapping.ListDataFrames(mxd)[0] df.spatialRefence = prj mxd.save() del mxd
import arcpy, sys mxd = arcpy.mapping.MapDocument("base.mxd") mxd.save() del mxd
import arcpy mxd = arcpy.mapping.MapDocument(r"D:\dataframesr\df_sr.mxd") df = arcpy.mapping.ListDataFrames(mxd)[0] prjfile = r"D:\dataframesr\ca_fips.prj" sr = arcpy.SpatialReference(prjfile) df.spatialReference = sr mxd.save() del mxd
