As noted in the referenced thread, you cannot create two independent "master"geodatabases in the same Oracle 11g instance. You could just use two differentusers in a single instance, or you could use the same owner name in two Oracleinstances. It would be unwise to use the same tablespace(s) in the formerconfiguration.- V
I've created in excess of 10,000 geodatabase instances in the past 18 years. I've neverhad difficulty creating multiple users in a single instance, then creating and registeringtables with the geodatabase as those users. "Enable Enterprise Geodatabase" only happens once, and the rest is just basic administration. If users can't create tables, that's a databaseadministration issue (missing required permissions).- V
