import arcpy, math, random #Read parameters linefc = arcpy.GetParameterAsText(0) #Roads feature class pointfc = arcpy.GetParameterAsText(1) #Known stream crossings feature class linefolder = arcpy.GetParameterAsText(2) #Workspace for culverts output culvertlen = int(arcpy.GetParameterAsText(3)) #Create intermediate and final feature classes linefc2 = linefolder + "/culverts" #Culverts file path pointfc2 = "in_memory/temppoints" #Intermediate, artificial crossings arcpy.CreateFeatureclass_management("in_memory", "temppoints", "POINT", "#", "#", "#", r"Coordinate Systems/Projected Coordinate Systems/Utm/Nad 1983/NAD 1983 UTM Zone 11N.prj") arcpy.CreateFeatureclass_management(linefolder, "culverts", "POLYLINE", "#", "#", "#", r"Coordinate Systems/Projected Coordinate Systems/Utm/Nad 1983/NAD 1983 UTM Zone 11N.prj") #Delete any existing features in culverts or artificial crossings if arcpy.Exists(pointfc2): arcpy.DeleteFeatures_management(pointfc2) if arcpy.Exists(linefc2): arcpy.DeleteFeatures_management(linefc2) #Find all crossings within 10m of a road arcpy.Near_analysis(pointfc, linefc, "10 Meters") #Find shape field in stream crossing feature class desc = arcpy.Describe(pointfc) pointshapefield = desc.ShapeFieldName #Create search and insert cursors rows = arcpy.SearchCursor(pointfc) insrow = arcpy.InsertCursor(pointfc2) #Enter for loop to create artificial crossings offset within 1m2 from actual crossing points for row in rows: #Continue if the crossing is <10m from a road if row.NEAR_DIST != -1: feat = row.getValue(pointshapefield) pnt1 = feat.getPart() pnt1x = pnt1.X pnt1y = pnt1.Y #Offset artificial crossing <=1m in X, <=1m in Y randomX = random.random() if randomX%2==0: randomX = randomX * -1 randomY = random.random() if randomY%2==0: randomY = randomY * -1 pnt2x = pnt1.X + randomX pnt2y = pnt1.Y + randomY #Insert new point into feature class feat2 = insrow.newRow() pnt2 = arcpy.CreateObject("Point") pnt2.X = pnt2x pnt2.Y = pnt2y feat2.shape = pnt2 insrow.insertRow(feat2) del row del insrow del rows #Calculate angle to nearest road arcpy.Near_analysis(pointfc2, linefc, "11 Meters", "#", "ANGLE") #Create search and insert cursors rows2 = arcpy.SearchCursor(pointfc2) insrow2 = arcpy.InsertCursor(linefc2) #Find shape field desc2 = arcpy.Describe(pointfc2) #Create array to hold new lines lineArray = arcpy.CreateObject("Array") #Enter for loop to create culverts for row2 in rows2: feat = row2.getValue(desc2.ShapeFieldName) pnt1 = feat.getPart() pnt1rad = math.radians(row2.NEAR_ANGLE) #Create point at far end of culvert pnt2 = arcpy.CreateObject("Point") pnt2.X = (math.cos(pnt1rad) * ((culvertlen/2) + row2.NEAR_DIST)) + pnt1.X pnt2.Y = (math.sin(pnt1rad) * ((culvertlen/2) + row2.NEAR_DIST)) + pnt1.Y #Create point at close end of culvert pnt3 = arcpy.CreateObject("Point") pnt3.X = (-1*(math.cos(pnt1rad) * ((culvertlen/2) - row2.NEAR_DIST))) + pnt1.X pnt3.Y = (-1*(math.sin(pnt1rad) * ((culvertlen/2) - row2.NEAR_DIST))) + pnt1.Y #Put points in array lineArray.add(pnt3) lineArray.add(pnt2) feat3 = insrow2.newRow() #Connect points and insert into feature class feat3.shape = lineArray insrow2.insertRow(feat3) #Erase points from array for next loop lineArray.removeAll() del row2 del insrow2 del rows2
