I have made a symbol in ArcGIS Pro, and would like to export it as a .PNG, .SVG or similar to use in other programs. Is this possible at all? I've only been able to export it as an Esri style file.
Thanks!
I also have this question. Did you get an answer elsewhere?
No
Any luck?
I haven't followed up on this since last summer, but below is a work-around a colleague suggested back in July 2019. It is less elegant than a direct export, but I was able to get the end result I needed with it.
"There’s no direct export symbol as sort of thing. I would create a small layout and have one feature and no basemap and export the layout as a PNG with transparent background."
I'm also curious whether there is a way to do this. Has anyone gotten an answer?
Is there any answer?
I want to export the ENC chart's symbology.
I also am trying to do this.
Make a layout
Make your symbol large and the only thing in the layout
Share the layout as an svg
I guess that's been answered, didn't see that, you could mark the other answer as the correct answer
