Im publishing a web map service with ArcGIS Pro 2.2.1 and ArcGIS server 10.6.1, the service is plublished inhttps://mysite.com/arcgis/rest/services/SIT/chs/MapServer and works succesfull.
But the automatic generated item at portal for that webmap has wrong url:https://mysite.com/portal/rest/services/SIT/chs/MapServer (Error 500) and the correct url must says /arcgis instead of /portal
Exist a configuration to set the url of service asociated to portal item?
If you look at the federation information for the Server through the Portaladmin API or the Sharing API, is it correct?
Jonathan, this is the configuration I see in portaladmin
Portal is running at https://mysite.com/portal and arcgis server is at https://mysite.com/arcgis
When clicking on validate, return the following message:
The services URL is incorrect. When you configure ArcGIS Enterprise, you'll install Portal, Server, the ArcGIS Data Store, and two web adaptors. At a basic level:
1) Create the portal (ex. https://portal.domain.com:7443/arcgis)
2) Create the server (ex. https://server.domain.com:6443/arcgis)
3) Register the Data Store with Server, (ex. https://data-store.domain.com:2443/arcgis
Then, you'll register the web adaptors. Let's say you install one called "server" to be registered for Server and one called "portal" to be registered with Portal.
4) Register the "server" web adaptor with Server and you'll be able to reach https://wa-machine.domain.com/server
5) Register the "portal" web adaptor with Portal and you'll be able to reach https://wa-machine.domain.com/portal
When federating, you'll use the Server URL with the web adaptor as the services URL and the you can use either the same URL as the admin URL or https://server.domain.com:6443/arcgis
Base ArcGIS Enterprise deployment—ArcGIS Enterprise | ArcGIS Enterprise
What is ArcGIS Enterprise Builder?—ArcGIS Enterprise | ArcGIS Enterprise
Tutorial: Set up a base ArcGIS Enterprise deployment—ArcGIS Enterprise | ArcGIS Enterprise
At this point, you can update the services URL manually.
Hi Jonathan!
We have already set 2 web adaptors, but you suggested that we have to make 2 subdomains and then register ours web adaptor.
We have 2 different urls now
the portal (subdoamin.site.com/portal) configured with web adaptor
the arcgis server (subdomain.site.com/arcgis) configured with another web adaptor.
The steps we've done was these:
1- create the subdomain
2- install webadaptor
3- set up webadaptor for portal
4- install webadaptor
5- set up webadaptor for arcgis
The portal and server installation was made in the same server. So we have only 1 server with the 2 services runnning
I don't understand what we could do now to solve this issue.
Thanks
Hello Igancio,
As per the screenshot it seems that the information passed in service URL is incorrect while setting up the federation (referred as URL in screenshot), it seems that it has the Portal URL passed where as the correct syntax is as follows (both the URLs passed here should be of ArcGIS Server):
Service URL: https://webadaptorhost.domain.com/webadaptorname
Admin URL : https://gisserver.domain.com:6443/arcgis
(Refer to "Federate an ArcGIS Server site with your portal" )
Both these URLs will be of ArcGIS Server. The easiest way to update that is to follow the steps mentioned below:
Hope it helps!
Regards,
Archit
Hello Archit,
I did your suggestions step by step.
I added a second server item with correct server url https://webad.domain.com/arcgis and is the one that I select when I publish with arcgisPro.
I already made the publication of a new map from arcgis pro and the item generated at portal continues with wrong url of the map service. It will be necessary to restart arcgisserver or something else?
Hi Ignacio,
Were you able to get past this problem? I'm having the same issue, I updated the Server URL, but newly published portal item still had the wrong url prefix.
