The best way to do this would be to set the FeatureLayer's selection symbol then call the selectFeatures() method.
Brian,You could always put a graphic on top of that feature?See this example.Hope this helps!Tim
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>CSS</title> <link rel="stylesheet" type="text/css" href="https://community.esri.com//js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body, #map { height: 100%; margin: 0; } #legend { position: absolute; right: 0; top: 0; width: 120px; background-color: #fff; padding: 5px; margin: 10px; border-radius: 5px; } path[data-name="Washington"] { stroke: rgb(54, 93, 141); stroke-width: 1pt; stroke-opacity: 1; fill: rgb(54, 93, 141); fill-opacity: 0.7; } path[data-name="Jefferson"] { stroke: rgb(160, 63, 60); stroke-width: 1pt; stroke-opacity: 1; fill: rgb(160, 63, 60); fill-opacity: 0.7; } path[data-name="Franklin"] { stroke: rgb(115, 140, 61); stroke-width: 1pt; stroke-opacity: 1; fill: rgb(115, 140, 61); fill-opacity: 0.7; } path:not([data-name="Washington"]):not([data-name="Jefferson"]):not([data-name="Franklin"]) { stroke: rgb(0, 0, 0); stroke-width: 0.4pt; stroke-opacity: 0.5; fill: rgb(255, 255, 255); fill-opacity: 0; } </style> <script src="//js.arcgis.com/3.8/"></script> <script> require(["esri/map", "esri/layers/FeatureLayer", "dojo/domReady!"], function(Map, FeatureLayer) { var map = new Map("map", { basemap: "oceans", center: [-98.5795,39.828175], zoom: 5 }); var layer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/3", { styling: false, dataAttributes: [ "name" ] }); map.addLayer(layer); }); </script> </head> <body> <div id="map"></div> <div id="legend"> <div align="center"><b>Most Common County Names in the US</b></div> <hr> <div> <svg width="12" height="12" version="1.1" xmlns="http://www.w3.org/2000/svg"> <path data-name="Washington" d="M 1 1 L 11 1 L 11 11 L 1 11 Z" /> </svg> <span>Washington (31)</span> </div> <div> <svg width="12" height="12" version="1.1" xmlns="http://www.w3.org/2000/svg"> <path data-name="Jefferson" d="M 1 1 L 11 1 L 11 11 L 1 11 Z" /> </svg> <span>Jefferson (27)</span> </div> <div> <svg width="12" height="12" version="1.1" xmlns="http://www.w3.org/2000/svg"> <path data-name="Franklin" d="M 1 1 L 11 1 L 11 11 L 1 11 Z" /> </svg> <span>Franklin (25)</span> </div> <div> <svg width="12" height="12" version="1.1" xmlns="http://www.w3.org/2000/svg"> <path data-name="Other" d="M 1 1 L 11 1 L 11 11 L 1 11 Z" /> </svg> <span>Other</span> </div> </div> </body> </html>
