try { // Create an instance of MobileCache, and set StoragePath MobileCache mobileCache = new MobileCache(); mobileCache.StoragePath = @C:\GIS\Project\Mobil\db(Cache)\cache; if (mobileCache.CacheExists) mobileCache.DeleteCache(); MobileServiceConnection conn = new MobileServiceConnection(); conn.Url = @"http://<server>/arcgis/rest/services/test3/MapServer/MobileServer"; // Create Mobile Cache Schema conn.CreateCache(mobileCache); // Open MobileCache mobileCache.Open(); // Use MobileCacheSyncAgent to download data from server MobileCacheSyncAgent agent = new MobileCacheSyncAgent(mobileCache); agent.MapDocumentConnection = conn; agent.DownloadExtent(mobileCache.FullExtent); //agent.Synchronize(); // Load layers from MobileCache to Map control map1.MapLayers.Add(mobileCache); //map1.Extent = mobileCache.FeatureSources[0].FullExtent; } catch (Exception ex) { MessageBox.Show(ex.Message); }
David and Petra,Another test you can run is to open the cache directly with ArcGIS Mobile rather than making a project through the MPC. If it works there, it could be a problem in the MPC.
Hi
I am also having the same issue - works fine on 10.2 but 10.2.1 caches are empty. 10.2.1 caches seem to work if the datum isn't projected but when a PCS is used the caches are empty?
Hi Ian-
Correct. I am still using the same method above at 10.2.2 for getting around empty caches when using HARN. Once the data frame has been given a correct transformation, whether from HARN to Standard State Plane or WGS84, then re-set back to HARN, the full caches will be created. A minor work-around really.
Thanks
David
Hello,
I had the same issue with ArcGIS for Server 10.2.2. After the publication of the service, the map and feature services work well, however, when I have added the mobile service to the Mobile Project Center, the map was totally empty. Furthermore, I was not able to create a full cache with the Create Mobile Cache Geoprocessing tool in ArcGIS for Desktop 10.2.2.
The projection of my data and dataframe is in the Dutch RD_new projection. After changing my dataframe to WGS84, a reset of the dataframe extent and changing it back to RD_new projection both the Geoprocessing Tool and Mobile Services works as expected.
Just a quick update. I've tested mobile cache creation and mobile sync tools on desktop 10.2.2 against a map and mobile service published to ArcServer 10.3 from a 10.2.2 desktop and there are no issues, excepting the projection bug mentioned throughout this post.
I have also successfully synced a mobile cache with with it's 10.3 service with no issues through an SDK application.
I will be testing the mobile project center projects against 10.3 mobile content server for any sync issues and report back
As noted earlier - I have successfully downloaded a mobile project from ArcServer 10.3 mobile content server and synchronized downloads and uploads from a 10.2 mobile project deployed on Windows 7-64. I am unable to test a Windows Mobile deployment.
By keeping a desktop at one of the 10.2 releases, you can continue to publish a map and mobile service to ArcServer 10.3, create the necessary mobile cache, download projects from the mobile content server, and synchronize data changes back to the server.
As soon as ArcGIS for Windows Mobile 10.2.1 comes out, I can update my remaining desktops.
This still does not work for me. I have tried changing the dataframe projection and extent many time but it still does not show any features in the mobile project center. My data is in NAD83 HARN MI stateplane south International feet. I have tried changing it to stateplane without HARN, resetting the extent, and then back, but no luck. I also tried creating the cache with reverting back to HARN, and again no luck. I tried removing the projected CS and just going with NAD83 and WGS84, nothing has worked. Features will not even appear when cache is created in one of these projections without reverting back to the original projection type.
I have done exactly what is being explained in the above replies but it has not worked for me. I am using 10.2.2.
Hi Petra, were you ever able to resolve this particular issue? I'm having the same problem and can't figure out a resolution. Thanks!
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
