Is there a setDefinitionExpression method for the QML API for feature layers?
I only see the method under the C++ API ref. Is there no way to do this in QML?
I'd recommend using the GeodatabaseFeatureServiceTable with the FeatureLayer. This is the direction moving forward for feature layer support in the Runtime. The ArcGISFeatureLayer is still provided for feature collections (initializing a feature layer from a feature set) because the Runtime API doesn't yet support that feature with the FeatureLayer using a FeatureTable.
I reproduced the problem and noticed that somewhere in the instantiation process of the declared GeodatabaseFeatureServiceTable, it is losing the definitionExpression. I'd recommend logging this as a bug through support. In the meantime as a workaround, you could wait to assign the definitionExpression when the feature table is initialized.
Here's an example:
GeodatabaseFeatureServiceTable {
url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Sync/WildfireSync/FeatureServer/0"
//definitionExpression: "eventtype = 1"
onFeatureTableStatusChanged: {
if (featureTableStatus === Enums.FeatureTableStatusInitialized) {
definitionExpression = "eventtype = 1"
Is this what you are looking for? ArcGIS Runtime SDK for Qt (QML API): ArcGISFeatureLayer
Steven
Isaiah, yes there is a definitionExpression on the GeodatabaseFeatureServiceTable: https://developers.arcgis.com/qt/qml/api-reference/class_geodatabase_feature_service_table.html#aa27d2b3227a39a2e21f7b0eb2f62eacb
ArcGIS Runtime SDK for Qt (QML API): GeodatabaseFeatureServiceTable
We recommend using the GeodatabaseFeatureServiceTable with a FeatureLayer in the QML API, unless you are working with feature collections in which the ArcGISFeatureLayer is the way to go.
Thank for the quick responses. I am coming from the JS API and was trying to use FeatureLayer with GeodatabaseFeatureServiceTable but I couldn't even get the points to draw with this setup. I am thinking it is because it does not honor the definitionExpresion I am inputting and without it there are a lot of points to try and draw.
I switched to the ArcGISFeatureLayer and all of the points draw but still no honoring of the definitionExpression. So I guess I have two questions.
Is there a specific method to execute in order to set the definition expression on a GeodatabaseFeatureServiceTable or ArcGISFeatureLayer? My current method is not working.
Current Method:
GeodatabaseFeatureServiceTable { id: incidentServiceTable url: "http://servername/arcgis/rest/services/servicename/MapServer/0" definitionExpression: "Day = 0" }
What is the difference between FeatureLayer and ArcGISFeatureLayer? Still not sure which one I should use with my point layer mapservice. In the JS API there was FeatureLayer but it seemed setup more like the QML ArcGISFeatureLayer. Plus it seems like ArcGISFeatureLayer is the only one that allows my points to draw on the map.
Any more help would be greatly appreciated!
Isaiah
