I'm getting this error message but it doesn't seem to be related to the renaming of layers.Here's what I've been doing:In ArcMap 10.2 (Win 7 64 bit), check out data from a feature class in a versioned 10.1 SQL Server Express geodatabase to an axf file.On opening the axf file in ArcPad 10.2 I get the Script Error.But if I do this:With the same setup, check out data from a feature class in a 10.2 file geodatabase to an axf file.It opens fine in ArcPad 10.2.In neither case have I changed any layer names in the TOC; both are simple point feature classes, and I didn't use a checkout template.Anyone have any further thoughts or different scenarios to offer?
Just updated our devices to 10.2 and are currently experiencing this error. Our layers are in a an SDE database powered by Microsoft SQL server. I tried looking into the layer name issue and everything appears the same. As a simple test I added just one layer to the project, exported it directly to arcpad, and opened it up. The same error keeps occuring.
Similar to what another poster mentioned, we are still able to ignore this error and add data, so maybe this isn't an issue worth pursuing.
Any news on this topic?
The dev team have been looking at this and believe its related to the Quick Fields implementation. Changes have been made and will be available in the next ArcPad release. You can confirm this yourself by disabling Quick Fields. To do this, delete (or move to a sub folder) the Quick Fields applet, and re launch your data in ArcPad.
Where do I remove this applet from? We are using the Get Data For ArcPad Extension.
Gregg,
What Marika suggests is to remove the applet from ArcPad itself. On my 64bit computer it is located at C":\Program Files (x86)\ArcGIS\ArcPad10.2\Applets". Remove all the files that start with "QuickField" (save them somewhere else in case you need them in the future) and give it a try. It worked for me.
Fantastic!!!
I have been working on this since Monday!
Our set up is: A GeoXT 6000 running Windows Mobile 6.1, ArcPAD 10.2 for Mobile, Trimble Positions Add-in for ArcPAD 10.2.
On PC: Windows 7 64bit SP1, ArcGIS Desktop 10.2, ArcPAD 10.2 for Desktop, Trimble Positions Add-in for Desktop 10.2.
I was receiving the same SQL error:
In order to remedy this solution I had to remove the QuickField Applets from the GeoXT 6000's program files.
Located at DeviceStorage/Program Files/Arc Pad/Applets
I created a sub directory called quickFieldBackup and moved all of the Files that started with QuickField into this.
Everything work great after that!
Thank you a ton!
James Hickey
Appears this problem is corrected in the latest release of ArcPad. (10.2.2)
Hi Guys!
I obtained the same error using ArcPad 10.2.2:
16:43:08 Synchronization started
16:43:08 AXF_FEATURE_SERVER_SOAP: http://srvgivsig01:6080/arcgis/services/OCP/inspeccionesDDV/MapServer/FeatureServer
16:43:08 AXF_FEATURE_SERVER_REST: http://srvgivsig01:6080/arcgis/rest/services/OCP/inspeccionesDDV/FeatureServer
16:43:08 AXF_TOKEN_URL: http://srvgivsig01:6080/arcgis/tokens/generateToken
16:43:08 Generating Token
16:43:08 Token: ZAyclYan1RhXaeTFrB_6AciCEVDZEx0HoiDZfh6xxaI.
16:43:09 Create unique constraint: UQ_SitiosInestables_Identifier
16:43:09 C:\Program Files(x86)\ArcGIS\ArcPad10.2\System\Scripts\Common\sync.js(1204, 7) Microsoft SQLServer Compact Edition OLE DB Provider: 0x80040e37: Major Error 0x80040e37,Minor Error 0. The specifiedtable does not exist. [ ]
16:43:09Synchronization completed
sorry for the delay in spotting this quesiton - still getting used to geonet.
Oswaldo the error you show here is quite different to the one displayed at startup that the others describe. Yours is to do with synchronization. Is your service secured perhaps? Are they point, line or polygon features and do they have z values? Some detail about your service will help pin point the problem.
