Jeremy, I am not sure why you are getting this error. When you look at this layer in the REST Service directory for you see the symbology for the point layer displayed?
//Legend Addition protected function initLegend():void { legendAC = new ArrayCollection([]); ParcelData.getAllDetails(new AsyncResponder(allDtlsResult, allDtlsFault,"ParcelData")); function allDtlsResult(event:AllDetails,lname:String):void { for each (var lDetails:LayerDetails in event.layersDetails){ if(lDetails.id > 0){ if(lDetails.drawingInfo){ //Add the layers name var layName:Object = { lname: lname, id: lDetails.id, otype: "layerName", label: lDetails.name, minscale: lDetails.minScale, maxscale: lDetails.maxScale, rend: null } legendAC.addItem(layName); if(lDetails.drawingInfo.renderer is com.esri.ags.renderers.UniqueValueRenderer) { var uv:UniqueValueRenderer = lDetails.drawingInfo.renderer as UniqueValueRenderer; for (var i:int=0; i<uv.infos.length; i++) { var uvObj:Object = { lname: lname, id: lDetails.id, parentlabel: lDetails.name, minscale: lDetails.minScale, maxscale: lDetails.maxScale, rend: uv.infos } legendAC.addItem(uvObj); } } if(lDetails.drawingInfo.renderer is com.esri.ags.renderers.SimpleRenderer) { var simObj:Object = { lname: lname, id: lDetails.id, parentlabel: lDetails.name, minscale: lDetails.minScale, maxscale: lDetails.maxScale, rend: lDetails.drawingInfo.renderer } legendAC.addItem(simObj); } if(lDetails.drawingInfo.renderer is com.esri.ags.renderers.ClassBreaksRenderer) { var cb:ClassBreaksRenderer = lDetails.drawingInfo.renderer as ClassBreaksRenderer; for (var j:int=0; j<cb.infos.length; j++) { var cbObj:Object = { lname: lname, id: lDetails.id, parentlabel: lDetails.name, minscale: lDetails.minScale, maxscale: lDetails.maxScale, rend: cb.infos } legendAC.addItem(cbObj); } } } } } } function allDtlsFault(event:FaultEvent):void { Alert.show(event.message.toString()); } } //End Legend Addition
Simon, You do need to compile it your self. I have always had bad experiences distributing compiled swfs in the past.
(not the precompiled version)
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
