Trying to eliminate the need to click on related records in a map to view structures and attachments related to a specific transmission structure. Is this possible? If not, Esri software continues to be a PITA, if so, how?
Yes this is possible with the Pro SDK.
https://github.com/esri/arcgis-pro-sdk/wiki/ProGuide-Custom-Pop-ups
Matt,
I downloaded 2019 Visual Studio and do not see the ArcGIS Pro SDK under the online extensions and updates. Can this be accessed with the community version?
Yes you can use the community version, but I needs be 2015 or 2017 I believe.
https://github.com/Esri/arcgis-pro-sdk/wiki/ProGuide-Installation-and-Upgrade
Is this ability to get information about related records going to be part of the out-of-the-box functionality of Pro, as opposed to the necessity for custom programming?
That's what I want to know. Seems like a PITA to be able to customize the popup with all data associated with that feature. Waste of my time when I am not a programmer and want to limit clicks to display related table info. Have not been impressed with Esri products. Structure is all over the place, way too many apps separate from one another, and verbiage that makes location and data more complex than it should be.
