OK, another question...
I'm running XP 64bit with Flash Player v 11.1.60....Installed Adobe Flash Player version: 10.3.181.34Required version: 11.1.0.0...My add/remove programs shows I'm running Flash Player 11.1.60
Requires Adobe Flex 4.5 SDK or higher, which in turn requires at least Flash Player 10.2.
M Lowry, You need to be using the agslib-3.0pre-2012-03-15.swc
Do you have a cross domain file under wwwroot? Really best way is to install locally and on the web server.
<?xml version="1.0"?> <!DOCTYPE cross-domain-policy SYSTEM "http://www.adobe.com/xml/dtds/cross-domain-policy.dtd"> <cross-domain-policy> <site-control permitted-cross-domain-policies="master-only"/> <allow-access-from domain="*" secure="false" /> </cross-domain-policy>
