A customer has provided a GDB with a single FeatureClass, but when we try and open the table we get a "FileGDB compression is not installed." error from the FileGDBAPI::Geodatabase::OpenTable call. Is there some way to open these files or install the FileGDB compression that Open Table is looking for? I can provide the GDB if needed.
Dear Lance Shipman,
have you got any news about the compressed data support for FileGDB?
filegdbfilegdb_api#
#filegeodatabase
Lance Shipman ha scritto:I've added an enhancement request for compressed data support and we will consider it for a future release.
We added support for reading compressed file geodatabase data at version 1.4 of the File Geodatabase API. The current version of the API can be found at file-geodatabase-api/FileGDB_API_1.5.1 at master · Esri/file-geodatabase-api · GitHub.
Hi @LanceShipman , when will the SDC Smart Data Compression support be added to the File Geodatabase API?
