Nicholas Furness
Anybody here with the experience of getting Enterprise ADFS login working with Xamarin Custom Android app using .net SDK?
When we click on Enterpirse login, the screen blanks account. In ESRI's Collector app, we get the popup for entering Username and password. We would like to get the similar behaviour for the user to enter the ADFS login credentials.
Thanks Tamilmani, Rajesh. Could you provide more info on the issues you're experiencing. For example, are you seeing any errors returned from the Runtime (and what are they)?
Nicholas Furness When we click on Enterpirse login, the screen blanks out. In ESRI's Collector app, we get the popup for entering Username and password. We would like to get the similar behaviour for the user to enter the ADFS login credentials.
Since it's a Forms app, does the code work on UWP and/or iOS? Curious if the problem is the code itself, or the android http stack.
Morten Nielsen Thank you for the reply. The app is particulary developed to work in Android Platform. Sorry, we never needed to test it on iOS. Also, I have tried the demo Authenticate with OAuth | ArcGIS for Developers , still it does not work as expected.
Could you please try the demo app you're referring to with a different platform then (iOS, UWP or Android) ? It would be very helpful for trouble shooting if we know whether we have to focus on an Android specific issue, or a general oauth issue with this specific authentication type.
Nicholas Furness We have tested against the Runtime WPF security login sample and that is does indeed work.
Thanks. That confirms it's most likely the Android HTTP Stack that has some problems with authenticating against that specific service. Unfortunately Xamarin.Android doesn't have a great single http implementation that fits all scenarios.I'd recommend trying picking a different HTTP stack for Android as documented here: HttpClient Stack and SSL/TLS Implementation Selector for Android - Xamarin | Microsoft Docs
