One suggestion is to set this up as a dymanically segmented route problemYour stream becomes a measured line feature and monitoring sites are events along the line.Geographic features such as river meanders are really just anacdotal in regard to the water flowing (unless you get meanders cut off...), so thinking of the stream as a line can be useful.
This question is still valid. I've had another project present itself where I need to display water quality along a line using a gradient colour scheme.
1.) Do your interpolation between the points. Don't worry that it will interpolate for areas far away from your line as well as on it.
2.) Buffer your line by some distance to make a line-shaped polygon.
3.) Extract the cells of your interpolation raster that overlap your buffer.
4.) Symbolize.
Thanks Darren! This is really helpful. Gonna give it a try
How do you do Step 3 Darren? Extract by Polygon tool asks for the X- and Y-coordinates of the polygon rather than the shapefile. Thanks!
Ah, yes, perhaps try Extract by Mask instead. Or, convert your vectors to a binary raster (0,1) and use Con to extract the desired pixels.
