All I'm trying to do is work out the query against the ESRI USA counties service using an input geometry.
https://services.arcgis.com/P3ePLMYs2RVChkJx/ArcGIS/rest/services/USA_Counties/FeatureServer/0/query
Point: -80.08364145199994, 26.69091499900003
I've tried setting the input spatial reference but still not getting the result I expect. At this point I simply want to work out the query at the REST interface.
Thanks
James,
Here:
https://services.arcgis.com/P3ePLMYs2RVChkJx/ArcGIS/rest/services/USA_Counties/FeatureServer/0/query?where=1%3D1&objectIds=&time=&geometry=-80.08364145199994%2C+26.69091499900003&geometryType=esriGeometryPoint&inSR=4326&spatialRel=esriSpatialRelIntersects&resultType=none&distance=0.0&units=esriSRUnit_Meter&returnGeodetic=false&outFields=*&returnGeometry=true&returnCentroid=false&featureEncoding=esriDefault&multipatchOption=xyFootprint&maxAllowableOffset=&geometryPrecision=&outSR=&datumTransformation=&applyVCSProjection=false&returnIdsOnly=false&returnUniqueIdsOnly=false&returnCountOnly=false&returnExtentOnly=false&returnQueryGeometry=false&returnDistinctValues=false&cacheHint=false&orderByFields=&groupByFieldsForStatistics=&outStatistics=&having=&resultOffset=&resultRecordCount=&returnZ=false&returnM=false&returnExceededLimitFeatures=true&quantizationParameters=&sqlFormat=none&f=html&token=
arghhhh… I forgot it needs the 1=1 in the where clause.
Thanks.
